TIPS Incoming Fax Detect
Joe Diamond CPA
Queue Callback Beta 5 is now available...
IMPORTANT: Custom return-call recordings must instruct customers to press 1 to connect.
Also available for download here.
mkdir qcallback
chown asterisk:asterisk qcallback
chmod 775 qcallback
cd qcallback
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/qcallback-17.0.5.0_Beta_5.tgz
tar zxvf qcallback-17.0.5.0_Beta_5.tgz
cd agi-bin
cp -p * /var/lib/asterisk/agi-bin/.
fwconsole ma install qcallback
/root/sig-fix
/root/sig-fix
fwconsole reload
just finished testing, all works well, just one issue (not really an issue0 BUT if you put in an alternate callback number the recording says press 1 to accept, when you do this it repeats itself and again says to press 1 to accept, then it works. WE ALL SHOULD GIVE A BIG THANKS TO KNERD! I sent hin $500 for his efforts in making incredible PBX a real contender as a modern PBX!! P.S. i am having trouble having the PBX listen for faxes? i followed wards instructions for installing faxing on IPBX 2027 and then the additional script installation to modify it for IPBX 2026? but not answering faxes? any help would be appreciated!
If you're still stuck, test with a dedicated DID and watch the Asterisk CLI during an incoming fax call. That should help establish whether the fax tone is being detected or whether the call is failing to reach the custom fax context.
Did you double check that the inbound route is set for fax detection? I don't know if that setting carries over if you import a backup from an older system.
Hi Kenn10, yes inbound route set to detect, per ward's instructions..................YES, SIP, NO (fax ring), 5 (rings), custom destinations Hyla Fax. i did everything wards IPBX 2027 said to do in addition the additional code for IPBX 2026 per his article.
i ran snfrep and saw no INVITE or UPDATE when sendind a fax to the PBX. I have it set up properly in incredible pbx, so my guess is that there is an issue with ward's wiki installing fax to \IPBX 2027 AND the additional code he mentions to add for IPBX 2026?
There is also a setting in the trunk:
anfecora
