TUTORIAL Incredible Wazo Upgrade to 17.17
Very helpful. Thanks. I had assumed you were using the documented upgrade procedure on the first page.
I was, but seeing you talk about 16.16.... (I went looking, in prep for my NUC coming tomorrow).
Upgrading to Wazo 16.16 Final Release
This upgrade includes Asterisk 14.2:
Also features Voicemail and Avatar support in WebRTC:
xivo-dist wazo-16.16
/etc/init.d/netfilter-persistent stop
wget --no-check-certificate https://raw.githubusercontent.com/wazo-pbx/xivo-upgrade/master/bin/xivo-to-wazo-upgrade
chmod +x xivo-to-wazo-upgrade
./xivo-to-wazo-upgrade
iptables-restart
sed -i 's|noload => app_cdr.so|;noload => app_cdr.so|' /etc/asterisk/modules.conf
sed -i 's|noload => app_festival.so|;noload => app_festival.so|' /etc/asterisk/modules.conf
sed -i 's|noload => cdr_adaptive_odbc.so|;noload => cdr_adaptive_odbc.so|' /etc/asterisk/modules.conf
sed -i 's|noload => cdr_csv.so|;noload => cdr_csv.so|' /etc/asterisk/modules.conf
sed -i 's|noload => cdr_odbc.so|;noload => cdr_odbc.so|' /etc/asterisk/modules.conf
sed -i 's|noload => cdr_sqlite3_custom.so|;noload => cdr_sqlite3_custom.so|' /etc/asterisk/modules.conf
sed -i 's|noload => func_cdr.so|;noload => func_cdr.so|' /etc/asterisk/modules.conf
sed -i 's|noload => func_odbc.so|;noload => func_odbc.so|' /etc/asterisk/modules.conf
# add Google Voice OAuth support for Asterisk 14
apt-get update
apt-get install git asterisk-dev libiksemel-dev -y
cd /usr/src
git clone https://github.com/sboily/asterisk-res-xmpp-oauth.git
cd asterisk*
make patch
make
make install
xivo-service restart
# put the Incredible PBX web add-ons back in place
cd /
wget http://incrediblepbx.com/incredible-nginx.tar.gz
tar zxvf incredible-nginx.tar.gz
rm -f incredible-nginx.tar.gz
ln -s /etc/nginx/locations/https-available/01_incrediblepbx /etc/nginx/locations/https-enabled/.
cd /etc/nginx
wget http://incrediblepbx.com/nginx-config.tar.gz
tar zxvf nginx-config.tar.gz
rm -f /etc/nginx/sites-enabled/default
/etc/init.d/nginx restart
sed -i 's|XiVO PBX|Wazo PBX|' /usr/local/sbin/pbxstatus
sed -i 's|`hostname -s`|Wazo|' /usr/local/sbin/pbxstatus
sed -i 's|13.|14.|' /etc/pbx/.version
sed -i 's|XiVO|Wazo|' /var/www/html/asteridex4/config.inc.php
sed -i 's|XiVO|Wazo|' /var/www/html/reminders/index.php
This upgrade will also load the terrific CDR CEL viewer from @Bart:
In the XiVO GUI, goto IPX -> Call Management -> Call Logs.
AsteriDex 4 (yourIP/asteridex4/) and Telephone Reminders (yourIP/reminders/) now use https! Don't forget the trailing slash to access the applications.
Hmm, I didn't get the CDR CDL viewer, and I had to disable Superfecta to get caller ID to work.
I haven't fully restarted the system since I installed; so I'll probably give that a shot before I scrap it entirely. I'm also willing to entertain the idea that Superfecta was my fault; it wasn't working entirely correctly before the update, but the update totally killed my caller ID. It's working well enough for now, the viewer is icing I wasn't expecting to get anyway.
Thanks for the tip, though.
Upgrading Wazo .anything to Wazo 17.17
cp -pr /etc/postfix /root
cp -p /etc/nginx/sites-enabled/xivo /root
echo "noload => res_xmpp_oauth.so" >> /etc/asterisk/modules.conf
xivo-dist wazo-17.17
apt-get update
wazo-upgrade
iptables-restart
cd /
cd /etc/nginx
cp -p /root/xivo /etc/nginx/sites-enabled
cp -pr /root/postfix /etc
/etc/init.d/postfix restart
sed -i 's|fr|us|' /etc/asterisk/indications.d/99-general.conf
/etc/init.d/asterisk restart
pbxstatus
DO NOT USE THE CODE BELOW WITH WAZO 17.14 OR ABOVE!!
If the version of Asterisk changes in the update from the version you already have, you'll also need to do the following to restore Google Voice OAuth 2 functionality:
cd /tmp
 cd asterisk-res-xmpp-oauth
 make patch
 make
 make install
I followed these instructions to update from Wazo 16.16 to Wazo 17.01. once completed, i'm unable to log into the web interface.
I am using a letsencrypt certificate. I followed the instructions here: http://documentation.wazo.community/en/stable/system/https_certificate.html
prior to upgrading, and everything was working fine...
I have checked the xivo-auth log, and i don't see the errors that indicate its a hostname issue.
Is it a password failure or an inability to access the web site?
Upgrading Wazo 16.16 to Wazo 17.01
xivo-dist wazo-17.01
wazo-upgrade
iptables-restart
cd /
cd /etc/nginx
pbxstatus
Is the procedure to upgrade from 17.01 to 17.02 the same as this?
Hello, wazo-upgrade is enough to upgrade 17.01 to 17.02. The next release 17.03 is planned for monday.
Time to make this a "click" process. Many products check for a newer version, offer to back up certain things and then the upgrade goes forward after confirmation. Seems like that wouldn't be hard to do on Wazo.
The script above does exactly that. The problem at the moment is fresh installs of the latest release. Because Incredible PBX uses a snapshot image of the Wazo database, it means we need a new snapshot with each new release because the devs regularly make database changes. Once we can build everything with API calls, this will go away.
I always get the following message at the end of a Wazo UPGRADE procedure....is this something I need to be concerned about?
Executing post-start upgrade action...
INFO:urllib3.connectionpool:Starting new HTTP connection (1): localhost
WARNING: The following configuration files were overwritten during the upgrade:
/etc/asterisk/res_odbc.conf
To finish the upgrade, you must merge the new version with the old
one. For example:
vimdiff FILENAME FILENAME.dpkg-old
Once this is done, remove the old files and run "xivo-service restart".
Compare the two versions of the files and add any missing pieces to modules.conf and res_odbc.conf.
Hi Ward,
I think CaC has fixed 10GB limit issue now. I see my disk space more than 38GB. Or maybe I misunderstanding.
