Installing apt-swift
echo /opt/swift/lib > /etc/ld.so.conf.d/cepstral.conf
ldconfig
amportal restart
I followed the directions and used a copy and paste so I didn't get anything wrong.
It all appears to work with the exception that after I dial 1234 and listen to Allison (sounds a little scratchy), I press a digit it says you pressed .... have a nice day where .... is silence. I pressed digit "8" and it never said it although it did recognize that I pressed a digit.
Suggestions?
Cheers
Garry
"swift command not found". Installed into the swift directory.... what did I do wrong. How to fix it??
You will need to execute this command from the unix command line if you haven't already.
ln -s /opt/swift/bin/swift /usr/bin/swift
