ISN: Free SIP Dialing from * Phones
In case it wasn't clear, I meant the dialplan on the phone itself, not in Asterisk. The article explains how to change it.
Ah, OK. I had changed that correctly, thanks.
I was able to install & access the NerdVittles demo from this article. Still no joy in Mudville otherwise. :-(
I am posting a more complete output from the logs in the hope that the error will be more easily seen by eyes more qualified than mine.
I believe I have a simpler approach for ISN dialing, modify
/var/lib/asterisk/agi-bin/enumlookup.agi
Enclosed is a patch I submitted to freepbx.
This way, it becomes just another enum dialplan.
I noticed that everytime dialplan reloads, the enumlookup.agi reverts back to the original code. How do you prevent this? So for ISN dialing, after using this patch, just send your call to the ENUM trunk?
you have an enumlookup.agi in the freepbx folder. That's the one that is copied back into asterisk every time freepbx is changing something.
thanks. so we'll need to change this file then:
/usr/src/freepbx/amp_conf/htdocs/admin/modules/core/agi-bin/enumlookup.agi
Yes... If you modify /var/lib/asterisk/agi-bin/enumlookup.agi
, I would
chmod 555 /var/lib/asterisk/agi-bin/enumlookup.agi
That way the file does not get overwritten. The only con to this, FreePBX will report
Failed to copy from module agi-bin
under FreePBX System Status.
Sorry for the confusion....
