R.I.P. Kazoo
It's version 4.3 @krzykat @KNERD
Host by myself
The documentation is quite bad. Once you get it installed, you can then start installing various applications on it. There is some sort of limited app market place on it. However, the premise is you make your own apps for it. They do have a "Making your first Kazoo App" on YouTube, but it was targeted for those who went to some convention.
@KNERD so when kazoo 5 is release than no more update for the opensource version.
All close source or will they open it later on?
There are also apps in github that you can try. It's taken me quite some time to get all the apps up and working as desired and our own VM Transcription, etc. But now we do have a true multi-tentant VoIP solution ... now to test it out and see if it is stable or not. I spoke for a while with Tony Lewis at ClearlyIP (big brain for FreePBX) about this yesterday at the ITexpo. He gave me a cautionary tale for using Kazoo. So make sure you test it extensively before implementing.
@krzykat thanks for the information. I just need one more thing... a routing call to carrier that use the good context(from-pstn) and not from-internal.
After that most of the feature are there.
We don't provide call to callcenter or ther things like that, We want to use kazoo as a FreePBX Like.
Replace 200 client FreePBX with one Kazoo
Kazoo 5 is closed source for now until its release. No recent updates on the status.
You can definitely do that. In Kazoo you have tenants - tenants can even be nested. Then you have "Numbers" app - this is where you assign the numbers at each tenant. Then process them how you like and as you would in FreePBX. I plan to use Kazoo in 2 different processes. One would be as a failover for FreePBX - to start with - just forward calls, or take voicemail, etc. But I've even played with having same extension numbers and going that direction. I think its doable, but a bit of work. Then the other process would be as a replacement to FreePBX. Still trying to get all the pieces in place that I want, but so far ... so good.
More info:
KAZOO master (5.x) is closed at the moment​
Development of KAZOO 5.x is currently closed to public commits as we prepare the infrastructure necessary for the app exchange. Once the infrastructure is ready, all developers - 2600Hz, partners, and open source community - will benefit from having the same build systems available, as well as a release channel from which folks can purchase those apps for use on any KAZOO cluster.
Thanks for your patience! We're excited to show 5.0 off!
Hope it's will be there quick.
More info:
You realize that was in October of 2020. I spoke to them on the phone back in December and was told to expect release in January ... here we are 6 months later and crickets. My fear is they will close it up, so think is best to take 4.3 and learn it. If 5.x comes out - then great, but don't want to wait on it.
Hosted solution starts at around $1500 / month
No wonder they have not been extremely helpful anymore on their forum. While they do help sometimes, you may only get one or two responses out of them before they go quiet.
This is my assumption as well. ... I'd be hopeful that the community could take off like this one has. But unfortunately, I think perhaps people that have learned the methods keep quiet thinking they don't want competition ?? Some folks do seem helpful and of course it is appreciated. They have done some things that make it better for their hosted business model at the expense of functionality though that I don't like. I've not gotten to the point, but my understanding is for example that they don't use PJsip, because then you could have let's say 10 phone devices, but it would only count as one on their hosted system, so they would potentially lose some income. I would have thought - open it up - if someone really wants all extensions to act and look as one and cheapen by having only one pay, then they are handicapped on abilities and that would make up such a small group of people, that you're throwing the baby out with the bath water.
Kazoo does use FreeSwitch, and has the ability to have more than one endpoint per extension. I guess they must it set ti only one endpoint in their hosted plan.
AI think they will release Kzaoo version 5, but I am guessing the CentOS 8 thing happened which probably set them back a bit, and I assumed they also want to make sure they get their app market done correct to monetize that.
Yes, its all about the app market. Honestly, I'm fine with it and I hope that people that decide to host on their own HW and want to lease apps from the app store can do so. I would think that's a win-win ... but ... we'll see. I mean - why isn't 5.0 on github? I think it used to be and people can play with it, suggest mods, contribute etc .... but not if its not available.
It is on GitHub, but they closed it off to the public a while back to concentrate on the app store release.
Yes, back in November, that is what I was told..... They must be having some real growing pains because I was told it would be done in January.
I really think it is the CentOS thing. Even Sangoma had a bit of a setback from that RedHat fiasco , but they have a lot more people working for them on it.
Sygaltech
