TIPS Multiple GV Trunks - Multpile Extensions - 1:1 inbound & outbound calling - Help please
When it auto configured, what did you get? I normally use the dynamicip option and NAT set to yes. How do you have Virtualbox network adapter setup?
I have a static IP address set on it so I can do port forwarding behind an ASUS router.
I will be using my device(s) from all over outside my network, so I can't lock things down and not allow outside connections and since apparent;y the iPhone doesn't like it, I have to leave it open.
I'll have several accounts set up on my phone at some point and really don't want to have to resort to the nifty "traveling man" access page.... so... the reasons for my insanity.
Nat is set to "yes" IP is set to "static". Still unable to register the device. Looking for anything remotely like the settings I was using in sip.config.
I'd have to reload that virtual machine and start it up again to tell you for sure. This is all totally new to me so I am not familiar with all the commands off the top of my head. I "might" recognize" a few if I saw them :)
As it stands now, I haven't modified a lot, and I'm trying to register the "yate" client using the default .
Now I got the default extension (701) to register with yate... trying to figure out why the one I just created won't register. Checking the obvious (passwords)
ok, I'm an idiot. I was trying to register with the display name and not the extension number for the new extension. Duh.
Moving on.
Ok. I got it regsistered.
I am able to make an outbound call over that GV trunk.
I am trying to set up an inbound route, but it says that one already exists for that trunk.
But it's not listed anywhere that I can see it.
When I dial the number for that trunk, the IVR picks up.
Not sure what happened, but i was finally able to create the inbound route that I wanted for this particular GV trunk.
It now connects directly to the extension I wanted it to.
I have the second trunk set up. I can call in and it is directed to the proper extension.
I set up a CID on the extensions that I use in the dialing pattern for the outbound route to direct outbound calls through that specific trunk.
So far, it looks like it was worth it to scrap everything and reinstall.
Now let me make a backup before I hose it again.
Thank you to everyone who helped. I really appreciate it!
