In Webmin | Servers | BIND DNS Server
I see three options to set up. I assume I need to pick the (2) internet server option as opposed to just (1) internal name server?
Update,
Thanks for the tip Joe (and everyone elses' help)
I set up BIND with Webmin, chosing option (2) Internet Server.
Did not do anything else.
I then turned off my dsl modem. Waited until the sip trunk with a fqdn (not a numeric ip address) failed to register. Waited a bit longer. I was still able to use an xlite sip extension to call into asterisk for the time, and was still able to dial out xlite to a zap trunk.
Seems to work well.
If someone else can confirm this, we should make it a sticky. This is a very useful tip.
Update,
Seems to work well.
This was the only solution I found worked to date, even if you rebooted or started asterisk.
