rick
- Dec 30, 2008
- 177
- 15
Problem I have been working on for the past few days.
ClearlyIP Appliance 716 using Centos 7, Incredible PBX 2020.2, Asterisk 16.13.0, Incredible 15.0.22.39, static IP address; this has been working perfect over the years until they lost power to the building.
Afterwards the Comcast had to replace their modem. Phone system came up and has on-way audio just on inbound calls. Outbound is two way audio. Checked sip settings - IP address and NAT are correct. SIP service is with SIPTRUNK, check their config, checked firewall, fail2ban and even turned off the firewall still no audio on in bound calls. Changed router no change. Return the original router.
Setup another trunk & number using VoIP.MS, audio in both directions inbound/outbound. Went to SIPTRUNK for an answers, they said send them data dump which I did, shows a completed connection.
While waiting on SIPTRUNK, in the meantime, I moved everything over to my PBX which is on Debian 11 in the cloud. I have the same problem no inbound audio in either direction; calling the DID has no audio. Calls made from that DID have audio.
Any ideas beside moving the number to another trunking company?
