NO JOY piaf3 borked install... help....
Destroy the lvm partitions and all other partitions and crest 3 new ones
look at my post on the previous page the partitions is NOT the problem. This time I did a manual create. I attached part of my putty log that shows tons of errors. one of then is a httpd that says there is a server limit of 5
thanks leon
hi there...you would think so but it was running almost an hour compiling something :-( I dont know where to go from here
I've installed PiAF on my test VM box before and never had this issue and I'm stumped.
just saw that the filenames for the guis have changed was using 11.4.centos.tar.gz or 12.4.centos.tar.gz
now need to restart again :-(
ldz
ok since I had an install running when I found the above I let it complete...it seems to croak at make install
see attached please
attached is a complete install toforum-20150524-1330.zip
the only thing I can think of is this is installing on an SSD.
Leon
ok I regressed. I reinstalled CentOS and used default partitioning and installed 3.6.5 Black and asterisk is running
a few minor errors and I attached the logs. So why doesnt the latest install please?
Thanks leon
For help on PBX commands you can use from this
command shell type help-pbx.
status: line 542: [: /dev/mapper/vg_pbx-lv_root: integer expression expected
status: line 544: [: /dev/mapper/vg_pbx-lv_root: integer expression expected
PBX in a Flash BLACK Status Program
qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq
lqqqqqqqqqqqqqqqqqqqqqqqqSYSTEM INFORMATIONqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x Asterisk = ONLINE | Dahdi = ONLINE | MySQL = ONLINE x
x SSH = ONLINE | Apache = ONLINE | Iptables = ONLINE x
x Fail2ban = ONLINE | Internet = ONLINE | Ip6Tables = ONLINE x
x Disk Free = ADEQUATE| Mem Free = ADEQUATE| NTPD = ONLINE x
x SendMail = ONLINE | Samba = OFFLINE | Webmin = ONLINE x
x Ethernet0 = ONLINE | Ethernet1 = ONLINE | Wlan0 = N/A x
x x
x PIAF Installed Version = 3.0.6.6 under *VMWARE* x
x FreePBX Version = 12.0.1beta10 x
x Running Asterisk Version = 12.8.1 x
x Asterisk Source Version = 12.8.1 x
x Dahdi Source Version = 2.10.0.1 x
x Libpri Source Version = 1.4.15 x
x IP Address = 10.195.13.191 on eth0 x
x Operating System = CentOS release 6.6 (Final) >< x
x Kernel Version = 2.6.32-504.16.2.el6.x86_64 - 64 Bit x
x x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
root@pbx:~ $
