SOLVED Several issues with fresh install of IncrediblePBX 2020 on Centos 7
Did a complete reinstall last night. Again the logfile was not working, so I followed the earlier post here to configure the logfile settings, but that still did not work. Was using Chrome as browser, so I decided to try Firefox. Logfile loaded normally!! Upgraded to Asterisk 17 and restored my backup. So far everything seems ok. Will continue to monitor.
If you do a fresh install and then logout and log back in, the Automatic Update Utility should sort out the logging issue.
Unfortunately that did not happen. I had logged in and out but that still did not sort out the logging issue. I had to adjust the settings and then switch to use Firefox browser. I still can't use Chrome browser to view the logs. I can see everything else with Chrome except the logs. Maybe something is wrong with my Chrome.
