SipToSis-Skype Gateway Tips
root@pbx:/siptosis $ ./SipToSis_linux
Launching SipToSis
Exception in thread "main" java.lang.NoClassDefFoundError: local.ua.SkypeUA
   at java.lang.Class.initializeClass(libgcj.so.7rh)
Caused by: java.lang.ClassNotFoundException: java.util.concurrent.TimeoutException not found in gnu.gcj.runtime.SystemClassLoader{urls=[file:jspeex.jar,file:sip.jar,file:ua.jar,file:skype.jar,file:log4j-1.2.15.jar,file:siptosis.jar,file:./], parent=gnu.gcj.runtime.ExtensionClassLoader{urls=[], parent=null}}
   at java.net.URLClassLoader.findClass(libgcj.so.7rh)
   at gnu.gcj.runtime.SystemClassLoader.findClass(libgcj.so.7rh)
   at java.lang.ClassLoader.loadClass(libgcj.so.7rh)
   at java.lang.Class.forName(libgcj.so.7rh)
Launching SipToSis
Launching SipToSis
Launching SipToSis
Launching SipToSis
Launching SipToSis
Probably too tired this evening...
Any pointers before I give up?
Got Skype working fine....just can't get SipToSis_linux to run..
Java looks correct:
root@pbx:/siptosis $ rpm -q jdk
jdk-1.6.0_12-fcs
This looks significant:
root@pbx:~ $ java -version
java version "1.4.2"
gij (GNU libgcj) version 4.1.2 20080704 (Red Hat 4.1.2-48)
Copyright (C) 2006 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
root@pbx:~ $
