Vital PBX 4 or 4.5 installation permissions issue.
Joe Diamond CPA
after installation, all of your DEFAULT sounds, messages and prompts in all the modules might be missing! Just figured out there were problems with permissions in some folders, if this occurs run this command.............
  • chmod +x /var/var/lib /var/lib/asterisk /var/lib/asterisk/sounds /var/lib/asterisk/sounds/en /var/lib/asterisk/sounds/en/vpb
It is likely that when installing vitalpbx, I did not have full root permissions, if anyone here can explain to my why this is or what i did incorrectly when installing (debian on crown cloud) I would appreciate it! thank you in advance, Joe
db2300
