Weather by Zip Code: THE MODULE
Do we have any current Elastix users running the current version 1.1.5 of this module?
Weather by Zip Module v 1.1.6 Released
I am please to announce the release and immediate availabililty of the Weather by ZIP Module v 1.1.6.
This is a reccomended maintenance release.
There is one change in this maintenance release.
1. Ticket #216 TTS Folder not being cleared by cron task.
There was an error in the code designed to purge the old tts files, which put warnings in the FreePBX cron manager (when it was run), and failed to clear the old tts files.
As always - let us know how this version works for you!
I just installed, but when I go to setup - weather by zip, I just get a blank page...
Any ideas??
P.S. I did not get any error during the install
Any ideas??
bump did you get this to work?
Blank Pages usualy mean security problems. Have you made changes to the default PBXIAF security? Mess with your Apche Security? More details means faster more complete help.
root@pbx:/ $ locate .htaccess
/usr/src/freepbx/amp_conf/htdocs/admin/modules/.htaccess
/var/pbx_load/misc/.htaccess
/var/www/html/admin/.htaccess
/var/www/html/admin/modules/.htaccess
/var/www/html/maint/phpMyAdmin/libraries/.htaccess
/var/www/html/welcome/.htaccess
root@pbx:/ $ locate weatherzip
root@pbx:/ $ locate weatherzip-1.1.6
root@pbx:/ $ find weather
find: weather: No such file or directory
root@pbx:/ $ find weather-1.1.6
find: weather-1.1.6: No such file or directory
root@pbx:/ $ find weatherzip-1.1.6
find: weatherzip-1.1.6: No such file or directory
find: weatherzip: No such file or directory
so when the module is uploaded and installed, where isit and what is it called
new install on PIAF 5414 update-scripts and update-fixes.
updated freepbx to 2.6.01
Had the same problem ona fresh install of fonicapabx
Had the same issue with an up to date system with FreePBX 2.6, and asterisk 1.4.29 (that the screen is blank on Weather by zip setup).
I unloaded it, and went with the 1.1.15.tgz and it then it loads up just fine.
Some of your questions - well, I just dont understand them. SOrry - Ill try again if you rephrase -
The module is inkstalled right along side all the other modules. FreePBX will create the folder during its installation. It ends up being called weatherzip.
Thats about all I can get from your questions. What is the nature of the problem, other than you couldnt find the module folder?
Blank white screen on configure after install.
So use locate or find to find weatherzip?
Where are the freepbx modules located?
Ok - I think I get it now. Your tyring to remove the HT.access file from the module because you are running a modified version of the PBXIAF security plan. (Be careful if your changing PBXIAF security. Its air tight, and you better really know what your doing or your mistake could be an expensive one )
Modules end up here : /var/www/html/admin/modules
We would be interested in knowing what changes you made to your default PBXIAF security that triggered this response in the ht.access file if thats what the problem ends up being. It may be we can write a better ht.access file with your feedback.
I think there must have been a security or some dependency issue between the versions. I had tried the install on a normal PBXINAFLASH install unsuccessfully. Reverted back one revision and then it worked fine.
Yes I think that may be a issue.
emailed Tshif with some additional information and they are looking into.
will post back.
just installed but getting no reports - log follows
  == Using SIP RTP TOS bits 184
  == Using SIP RTP CoS mark 5
  == Using UDPTL TOS bits 184
  == Using UDPTL CoS mark 5
    -- Executing [*947@from-internal:1] Goto("SIP/1000-00000012", "noah-swift,s,1") in new stack
    -- Goto (noah-swift,s,1)
    -- Executing [s@noah-swift:1] Answer("SIP/1000-00000012", "") in new stack
  == Manager 'phpagi' logged on from 127.0.0.1
  == Manager 'phpagi' logged off from 127.0.0.1
    -- Executing [s@noah-swift:2] Wait("SIP/1000-00000012", "1") in new stack
    -- Executing [s@noah-swift:3] Set("SIP/1000-00000012", "TIMEOUT(digit)=7") in new stack
    -- Digit timeout set to 7.000
    -- Executing [s@noah-swift:4] Set("SIP/1000-00000012", "TIMEOUT(response)=10") in new stack
    -- Response timeout set to 10.000
    -- Executing [s@noah-swift:5] Swift("SIP/1000-00000012", ""At the beep enter the five digit zip code for the weather report you wish to retrieve."") in new stack
    -- Executing [s@noah-swift:6] Read("SIP/1000-00000012", "ZIPCODE,beep,5") in new stack
    -- Accepting a maximum of 5 digits.
    -- <SIP/1000-00000012> Playing 'beep.gsm' (language 'en')
    -- User entered '59937'
    -- Executing [s@noah-swift:7] Swift("SIP/1000-00000012", ""Please hold a moment while we contact the National Weather Service for your report."") in new stack
    -- Executing [s@noah-swift:8] AGI("SIP/1000-00000012", "nvweather-zip.php|59937") in new stack
    -- Executing [s@noah-swift:9] NoOp("SIP/1000-00000012", "Wave file: ") in new stack
    -- Executing [s@noah-swift:10] Playback("SIP/1000-00000012", "") in new stack
  == Spawn extension (noah-swift, s, 10) exited non-zero on 'SIP/1000-00000012'
happens with either speech engine
swift is a registered installation
Ideas/suggestions?
Myk
Myk - Where is your swift executable located in the file system?
i dont think swift is the problem as i get the zipcode prompts played but anyways
orig is /opt/swift/bin/swift with symlink of /usr/bin/swift pointing to actual location
the php script acts like it don't retrieve the info and create the wav file
also looking in the /var/lib/asterisk/agi-bin dir i have
root@pbxtcs:/var/lib/asterisk/agi-bin $ ls -la nv*
-rwxrwxr-x 1 asterisk asterisk 22K Aug  1 13:02 nv-weather-zip.php*
-rwxr-xr-- 1 asterisk asterisk 23K Aug  2 04:47 nvweather-zip.php*
dunno which one the system is actually using....
It using /var/lib/asterisk/agi-bin/nvweather-zip.php
And I can confirm failure on 1775. This project is dependant upon pear.db functions - I dont know if they have been included in 1775 - do you know?
