GO HERE PJSIP on RPi2 - Anyone have it working?
jerrm
PJSIP does not work on RPi2 builds using http://nerdvittles.com/?p=14787.
PJSIP starts out flaky and degrades to complete unresponsiveness.
I've tried it on several Pi installs. Went back and did a fresh virgin install, carefully monitored for errors. Only post-install configuration was to enable PJSIP. Still broken/same results.
A fresh IPBX iso install to an ESXi VM works. A new raspbx install works. It only seems broken on IPBX/RPi2. All tested with the same endpoints.
I haven't dug into comparing the Pi and iso build scripts yet. Hoping someone knows the issue and has a fix.
Have you tried from the CLI to upgrade asterisk to latest?
Leon
The fresh build is already the latest 13.7.2. The others are 13.7 builds.
I had all sorts of issues with BLF and what not and once I did the upgrade from CLI that solved a pile of problems. I think just recompiling it was the key
ldz
Recompile/Install didn't help on Wheezy.
The Jessie version APPEARS to be OK. Still need to stress it some, but it seems OK on the first pass.
