The upgrade to Asterisk 17 did go through after all. I was getting things confused. When I did a "pbxstatus" from a SSH connection I can see "Aserisk 17.7.0 Incredible GUI 15.0.12.24", but the Dashboard was showing "Incredible PBX 2020 15.0.16.73.1" I was not reading thoroughly. Sorry about that. I would like to continue to try to rescue this system before I try a fresh install. I guess I can learn more this way. I believe if I tighten up the firewall I can solve some issues. So my only issue may be the " Log files". I configured the Log Files settings as per the instructions posted, but mine is still not working.
I don't have any port forwarding on the router.
I will send the snippets once I can get the logs working again.
I plan to do a fresh install tomorrow if I cant this this right. I see there is a Backup and Restore module. Thought I could just backup the necessary configs, but this is showing 62 modules. Which are the most important? Can i backup to a Flash drive?
