ALERT Buh-bye CentOS.
Running an incrediblerestore2021, I get "tar: Exiting with failure status due to previous errors". Is this expected?
Sad.
Well looks like back to 3CX.
At least won't have to worry about getting a DID Provider configured or a phone.
It's already built-in.
FreePBX could do the same thing to IncrediblePBX with Non-GPL code as well.
Over the years, as I started with CP/M as well.
RedHat did this back around 2002 (I think) when they went Commercial, and announced the GPL version would now be Fedora.
Debian/Ubuntu didn't even exist back then.
Only disto that hasn't come and gone is FreeBSD.
FYI: Both Incredible PBX 2020 and Incredible PBX 2021 self-configure for Skyetel trunks. All you have to do is sign up on their site. Other trunk providers are preconfigured as well. All you have to do is enable the desired trunk after signing up with the provider. Works no differently than 3CX. Preconfigured extensions have been provided in Incredible PBX since its inception.
3CX has the different manufacture phones setup in it. No configuration.
I like Incredible PBX with Avant Fax and Lenny.
Thanks, @kenn10.
If you've already downloaded Incredible PBX 2021 and decided to use Incredible Fax, please apply the following patch after installing Incredible Fax to eliminate registration errors in the logs.
Fresh downloads of Incredible PBX 2021 already have the patch applied.
cd /etc/iaxmodem
sed -i s'/^refresh.*/refresh\t\t60/g' /etc/iaxmodem/*cfg.tty*
systemctl restart iaxmodem
fwconsole restart
fwconsole reload
The colorful Ubuntu link in Ward's writeup on Nerdvittles points to the Debian version. Is there any reason this should not work on Ubuntu, or why are people so skeptical?
I'm thinking of giving it a try on an Odroid C2 with a Ubuntu 20.04 minimal image. Any thoughts?
has any one had issues with mysql in the 2021 version? i am useing chan sccp B and the real time config shows the module missing.
Well, Besides the version checks for Debian 10, and Buster backports installed, and Php 5.6 that is specific to Debian Buster...
I modified the install script, and installed it on ubuntu 20.04 LXD container, and it seems to mostly work.
Diff:
--- IncrediblePBX2021.sh    2021-01-21 16:57:17.000000000 -0500
+++ IncrediblePBX2021-u.sh    2021-01-24 19:23:50.000000000 -0500
@@ -84,18 +84,18 @@
 read -p "Otherwise, press Enter to proceed at your own risk..."
-debian=`cat /etc/debian_version`
-if [[ "$debian" > "10.0" ]]; then
- proceed=true
-else
- proceed=false
-  echo " "
-  echo "********* WARNING WARNING WARNING WARNING *********"
-  echo "Debian 10.7 is the requuired platform at this time."
-  echo "********** WARNING WARNING WARNING WARNING ********"
-  echo " "
-  exit 6
-fi
+# debian=`cat /etc/debian_version`
+# if [[ "$debian" > "10.0" ]]; then
+#  proceed=true
+# else
+#  proceed=false
+#   echo " "
+#   echo "********* WARNING WARNING WARNING WARNING *********"
+#   echo "Debian 10.7 is the requuired platform at this time."
+#   echo "********** WARNING WARNING WARNING WARNING ********"
+#   echo " "
+#   exit 6
+# fi
 clear
 echo ".-.                          .-. _ .-.   .-.            .---. .---. .-..-."
@@ -128,12 +128,12 @@
 DEBIAN_FRONTEND=noninteractive
-sed -i 's|rm -i|rm -f|' /root/.bashrc
-sed -i 's|cp -i|cp -f|' /root/.bashrc
-sed -i 's|mv -i|mv -f|' /root/.bashrc
-echo deb http://ftp.us.debian.org/debian/ buster-backports main > /etc/apt/sources.list.d/backports.list
-echo deb-src http://ftp.us.debian.org/debian/ buster-backports main >> /etc/apt/sources.list.d/backports.list
+# sed -i 's|rm -i|rm -f|' /root/.bashrc
+# sed -i 's|cp -i|cp -f|' /root/.bashrc
+# sed -i 's|mv -i|mv -f|' /root/.bashrc
+# echo deb http://ftp.us.debian.org/debian/ buster-backports main > /etc/apt/sources.list.d/backports.list
+# echo deb-src http://ftp.us.debian.org/debian/ buster-backports main >> /etc/apt/sources.list.d/backports.list
 apt-get update
 #apt-get upgrade -y
 apt-get install -y build-essential openssh-server apache2 mariadb-server mariadb-client bison flex php \
@@ -212,7 +212,7 @@
  cd /usr/src/asterisk-16*
 fi
-### add expect code to trap telcode =1
+### add expect code to trap telcode =1
 # install on server
 if [[ "$ASTVER" = "18" ]]; then
@@ -524,14 +524,15 @@
 # PHP 5.6/7.3 Dual Boot Setup with 5.6 as default to support Incredible Fax and AvantFax
 apt-get install software-properties-common -y
-wget -q https://packages.sury.org/php/apt.gpg -O- | apt-key add -
-echo "deb https://packages.sury.org/php/ buster main" | sudo tee /etc/apt/sources.list.d/php.list
+# wget -q https://packages.sury.org/php/apt.gpg -O- | apt-key add -
+# echo "deb https://packages.sury.org/php/ buster main" | sudo tee /etc/apt/sources.list.d/php.list
+add-apt-repository -y ppa:ondrej/php
 apt-get update
 apt-get install php5.6 -y
 apt-get install php5.6-bcmath php5.6-curl php5.6-gd php5.6-intl php5.6-ldap php5.6-mbstring php5.6-mysql php5.6-xml -y
 sed -i 's|128M|256M|' /etc/php/5.6/apache2/php.ini
 sed -i 's|128M|256M|' /etc/php/5.6/cli/php.ini
-a2dismod php7.3
+a2dismod php7.4
 a2enmod php5.6
 update-alternatives --set php /usr/bin/php5.6
 systemctl restart apache2
@@ -639,4 +640,3 @@
 read -p "Press Enter to reboot or Ctrl-C to exit..."
 /usr/local/sbin/reboot
Hylafax status and UCP Dmon don't seem to work, according to the /root/pbxstatus.. But even on a Debian container, the Hylafax doesn't seem to work... Probably because it is an unprivlaged container, and the host may be missing the kernel modules.
Yepp, I can confirm: it is possible to use on Ubuntu platform.
But with using an Odroid C2 you have the additional challenges of needing modules for arm64 (<>amd64) hardware platform.
Here's the install script I ended up using (see attached zip).
With special thanks to @jaminmc, I think we're ready for the Ubuntu 20.04 PIONEERS:
wget http://incrediblepbx.com/IncrediblePBX2021-U.sh
chmod +x IncrediblePBX2021-U.sh
./IncrediblePBX2021-U.sh
Eslyv3EW4AcVMdO
Successfully tested at Vultr. Two also built at CloudAtCost using Ubuntu 18.04 upgrade and new way with Ubuntu 20.04.
Not sure why but, on some Ubuntu builds, UCP daemon is going out to lunch. fwconsole reload also seems to croak unless you first remove the contents of the /tmp folder.
A ucp-fix script to rebuild the affected modules seems to fix UCP so I've added it to the default scripts in /root. If we keep seeing the problem, we'll add it to the installer as well. Here's ucp-fix if you have the problem with existing installs:
#!/bin/bash
read -p "This script rebuilds UCP-dependent modules. Ctrl-C to exit."
fwconsole restart
fwconsole ma remove clearlytrunking
fwconsole ma remove sms
fwconsole ma remove ucp
fwconsole ma remove api
fwconsole ma remove pm2
fwconsole ma downloadinstall pm2 api ucp sms clearlytrunking
fwconsole restart
rm -rf /tmp/*
fwconsole reload
#!/bin/bash
fwconsole restart
fwconsole restart
rm -rf /tmp/*
fwconsole reload
I think it may be better to move the rm -rf /tmp/* to just after removing the modulus....
Like this:
#!/bin/bash
fwconsole restart
rm -rf /tmp/*
fwconsole restart
fwconsole reload
read -p "Press Enter to reboot, or Ctrl-C to exit."
reboot
That way the tmp folder is clean for the Re-install.. Added a Reboot also, in case removing the contents of /tmp causes other things to go wonky
What's the benefit of Ubuntu over Debian?
Debian vs Ubuntu As Server Environments
Both systems work well as servers, but Debian Stable releases usually come with time-tested and therefore, theoretically more stable software. This makes them preferable when it comes to stability. Their single downside is their software is often dated when compared to other distros.
Ubuntu offers a separate server installation image, and it can be as lean as a Debian system. It’s the preferred alternative if you need certain features that are only available in updated software. Ubuntu servers are also relatively stable, but the simple truth remains, that the systems aren’t as time-tested as Debian Stable systems.
I've been using Ubuntu for a while. My home and office servers are Ubuntu, and I run a bunch of LXD Containers. IncrediblePBX seems to work just fine in a container, except for Dahdi, as I haven't figured out how to get that to work in a container yet... So that prevents me from using it for Fax's. Then again, LXD can now also do Virtual machines now... So I can always try that. The thing I love about LXD containers is that the OS's that run in the containers share the host Kernel. So no need to emulate hardware to another Kernel, and it uses less resources in the process... But IT has its limitations also...
Now Debian can do the same thing, as Ubuntu is based on Debian. I personally like having newer versions of packages. :)
Just circling back on the Ubuntu build. Admittedly, CloudAtCost is a horrible platform on which to reach any conclusions, but...
What we're seeing with 2 different Ubuntu 20.04 builds there (one built using their upgraded 18.04 image and a second built from 20.04 ISO using methodology of @jaminmc above), BOTH die within the 6-8 hour time frame. While I would blame it on CloudAtCost, I don't think that's the case here because we have Debian and CentOS platforms that have been working for weeks and months without a problem.
Hope this isn't a platform design defect but BUYER BEWARE.
I'm going to bring up an Ubuntu test server on Vultr and let it run for a few days to see what we see.
Good thing the Blog entry is BETA :)
I'll spin one up on Digital Ocean. That should be a little better....
Going through the script, I see some things that need changing... Trying them now.
hostgsm
