ostridge
- Jan 22, 2015
- 1,813
- 625
This uses wards code as #18Sorry I started from wrong dir - it is in there now running
Server pbxstatus=
Incredible PBX 2020.3 for Raspberry Pi 3B
Asterisk: UP Apache: UP MySQL: UP
Exim: UP IPtables: UP SSH: UP
UCP Dmon: UP PortKnock: UP NR VPN: UP
FaxGetty: DN IAX Modem: DN HylaFax: DN
RAM:50316 *Raspbian 10 buster* Disk:262G
Asterisk 16.16.0 Incredible GUI 15.0.12.68
Private IP: 192.168.1.242 192.168.1.24
make[1]: Leaving directory '/usr/src/asterisk-16.18.0/menuselect'
Generating input for menuselect ...
menuselect/menuselect --check-deps menuselect.makeopts
The existing menuselect.makeopts file did not specify
that 'test_scope_trace' should not be included. However, either some
dependencies for this module were not found or a
conflict exists.
Either run 'make menuselect' or remove the existing
menuselect.makeopts file to resolve this issue.
make: *** [Makefile:364: menuselect.makeopts] Error 255
conflict exists.
Running Incredible PBX shutdown...
