I used the Ubuntu 20.04 virtual machine offering. Then the Oracle firewall doesn't get in the way.
Each tenancy gets the first 3,000 OCPU hours and 18,000 GB hours per month for free to create Ampere A1 Compute instances using the VM.Standard.A1.Flex shape (equivalent to 4 OCPUs and 24 GB of memory). Each tenancy also gets two VM.Standard.E2.1.Micro instances for free.
Select Ubuntu as the Image. AMD is the default Shape. Switch to Virtual Machine -> Ampere and grab the biggest size you can get for the Shape.
If you switch to Ampere, then you'll have a aarch64 machine, using AMD you get x64. You have AMD selected in your screen shot, not Ampere, with 1 core & 1 gig of ram.
The Pi is aarch64, right. So in theory, a script can be built to install the proper components....
Right now, the Ubuntu script installs (on aarch64), but Asterisk crashes....a lot...
The screenshot was to show how to activate the Ampere Shape with their VM. AMD is the default Shape until you change it.
Ok, so yours is running Ubuntu for ARM, 3 cores and I assume 8 gigs of RAM, according to your screen shot in the other thread.
Did you do anything special to make it work?
Does asterisk crash when you apply config?
1. Ok, so yours is running Ubuntu for ARM, 3 cores and I assume 8 gigs of RAM, according to your screen shot in the other thread.
2. Did you do anything special to make it work?
3. Does asterisk crash when you apply config?
1. Correct. It's whatever their Ubuntu 20.04 VM Image provides.
2. No.
3. No. Once in a while, there's an alert that the Dashboard can't connect to Asterisk, but refreshing the Dashboard fixes it.
I was in the Asterisk console, everytime I applied config, I was booted out. That tells me, on mine, asterisk stopped and started. Maybe not a crash, but an unexpected restart?
That's good news
24 x 30 = 720 hours per cpu?
So 4 1 cpu 6 gb ram instances gets to 2,880 hours
Managed to snag one with OCPU count of 3
I have an ocpu count of 4 Ubuntu minimal image.
==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
iPBX install asking password for ubuntu - is it ubuntu by any chance? oops silly question do
sudo su  && cd /root/
But when I login as root [code]
Using username "root".
Authenticating with public key "imported-openssh-key"
Please login as the user "ubuntu" rather than the user "root".
Then without a bye your leave the b****y putty window disappears.[/code]
Instance still loading query 44 country code I be that doesnot load the en_GB sounds does it?
You have to use keys to login as Ubuntu, then sudo reset root password, then Su to root.
Yes I have been using the .ppk private key worked great before the asterisk install. After reboot cannot connect now. Anyone know the troubleshooting route in?
Probably same thing I had happen. Ip tables blocked you. Reinstall, fix firewall before reboot.
chmod 700 .ssh/ubuntu
ssh -i .ssh/ubuntu ubuntu@server-ip-address
Safest course is to be sure you install OpenVPN before you reboot. All of the 10.8.0.x subnet is whitelisted.
To autostart OpenVPN client, copy .ovpn into /etc/ and name it incrediblepbx.ovpn. Then reboot.
This should already work but, if not, go here.
Bash:
~#   ssh -i .ssh/oracle-private-rsa_ssh-key-2021-10-08.key [email protected]
ssh: connect to host 140.xxx.xxx.xxx port 22: Connection timed out
Above my pay grade, but I think the file name in .ssh has to match the login user's name, i.e. ubuntu:
CSS:
cd .ssh
mv oracle-private-rsa_ssh-key-2021-10-08.key ubuntu
cd ..
shodan
