kenn10
Well-Known Member
- Dec 16, 2007
- 4,630
- 3,002
Check the SIP and PJSIP ports your Vultr instance is using (Settings > Asterisk SIP Settings) and make sure your W52P is steered to the correct SIP or PJSIP port on the new system. You might also want to migrate your extensions and trunks on the new system to chan_pjsip since chan_sip is end-of-life on Asterisk. Default port numbers have changed since PIAF.
