ALTERNATIVE FW from obifirmware.com
taoman - for OBi2000 series
Installation instructions:
Install stock 4983.
Install OBi2000-6-2-3-4907-signature-bypass.fw.
md5sum OBi2000-6-2-3-4907-signature-bypass.fw = 24d0bcad8601d96b5f6b05120181c967
Next, install OBi2000-6-2-3-5330-taoman3.fw.
md5sum OBi2000-6-2-3-5330-taoman3.fw = c403c79f49e3694e72a40da93c770c01
Changes:
enable dropbear ssh server. default root passwd = "obi".
patch OBiapp to bypass "zero touch" forced configuration. added clear_zt_params util to clear old zero touch params.
patch OBiapp to bypass signed firmware check when loading new fw
patch OBiapp to bypass GVSIP provisioning lock
NEW: fix audio problem during conference calls
NEW: add Google Voice config instructions to webgui
NEW: changed GV AuthPassword override format to only require the refresh_token itself (backward compatibility mode is enabled if AuthPassword being with "client=" so no config changes are required)
NEW: make full root Certificate Authority list user-editable at /scratch/rootca.pem (by default symlinked to 2024-11-26 mozilla/curl root CA list from curl.se/ca/cacert-2024-11-26.pem)
Mod implemented using a new technique of adding code to the padding at the end of an ELF segment instead of overwriting functions inline, because this fw uses oauth in more places.
Noting support from the now DEAD DSLREPORTS
https://www.dslreports.com/forum/voip
