FYI OBi2182 Resurrected with Google Voice
Nice one but no delivery to UK we may have been 'Trumped' lol. - It says
"This item cannot be shipped to your selected delivery location.
Please choose a different delivery location.
Deliver to United Kingdom "
Since this US Amazon Renewed item shipped by the seller and they are not making it available for direct shipping to the UK, you can use a third-party package forwarding service to ship it to you in the UK.
That would probably make the overall cost so high that it would no longer be attractive.
@ostridge if you have a US friend, they probably would reship it for you for the cost of economy shipping, plus a beer or coffee, great phone, worth a try.
Here is a short note about Obi2182 firmware updating. which may be of interest.
Original stock firmware for Obi2000 = Obi2000-6-2-3-4946.fw   (= Obi2000.6.2.3.4946.1311)   NOT held.
Subsequentially loaded stock 4907
From stock 4907, loaded   stock 4983 to allow reverting to taoman's 4907-signature-bypass
Then upgraded to Taoman's 5330 alternative FW from obifirmware.com
I noticed that
For the record I have some STOCK firmware files as follows, maybe they could be hosted in the repo somewhere ?>
Obi2000 series desk Phones
4946 ( as delivered but not available)
OBi2000-6-2-3-4907.fw
OBi2000-6-2-3-4983.fw
OBi2000-6-2-3-5330.fw
ALTERNATIVE FW from obifirmware.com
taoman - for OBi2000 series
Installation instructions:
    Install stock 4983.
    Install OBi2000-6-2-3-4907-signature-bypass.fw.
    md5sum OBi2000-6-2-3-4907-signature-bypass.fw = 24d0bcad8601d96b5f6b05120181c967
    Next, install OBi2000-6-2-3-5330-taoman3.fw.
    md5sum OBi2000-6-2-3-5330-taoman3.fw = c403c79f49e3694e72a40da93c770c01
Changes:
    enable dropbear ssh server. default root passwd = "obi".
    patch OBiapp to bypass "zero touch" forced configuration. added clear_zt_params util to clear old zero touch params.
    patch OBiapp to bypass signed firmware check when loading new fw
    patch OBiapp to bypass GVSIP provisioning lock
    NEW: fix audio problem during conference calls
    NEW: add Google Voice config instructions to webgui
    NEW: changed GV AuthPassword override format to only require the refresh_token itself (backward compatibility mode is enabled if AuthPassword being with "client=" so no config changes are required)
    NEW: make full root Certificate Authority list user-editable at /scratch/rootca.pem (by default symlinked to 2024-11-26 mozilla/curl root CA list from curl.se/ca/cacert-2024-11-26.pem)
Mod implemented using a new technique of adding code to the padding at the end of an ELF segment instead of overwriting functions inline, because this fw uses oauth in more places.
Noting support from the now DEAD DSLREPORTS
 https://www.dslreports.com/forum/voip
Would you happen to have the 4983 file that I could purchase? I can’t seem to find it anywhere and my phone just died lol
What's the best easiest quickest way to invalidate (aka block) the login token for a lost or stolen obi2182 with obifirmware.com firmware installed for google voice support in 2026? The goal is to prevent the person who found it from connecting to local WiFi and start receiving calls and having the ability to make calls on the assigned GV number.
If you log into your account and go to https://voice.google.com/u/0/settings, look for My Devices.
The Obi devices for your account should be listed there. However, it's going to be up to you which one to remove if you have more than one unless you know the ObiTalk number the device had assigned. Good luck!
Tyler Giansante
