NEW iPBX 2026 Queue Callback beta4
well, that didn't work but I think this will but I can't test it at the moment:
cd /var/lib/asterisk/sounds/en/custom
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/queue-press*-to-request-callback.wav
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/queue-returning-your-call.wav
chown asterisk:asterisk *
cd ..
mysql -u root -ppassw0rd asterisk -e "INSERT INTO recordings (displayname, filename, description) VALUES ('Queue Returning Your Call', 'custom/queue-returning-your-call.wav', 'Added via CLI');"
mysql -u root -ppassw0rd asterisk -e "INSERT INTO recordings (displayname, filename, description) VALUES ('Queue Press Star to request Callback', 'custom/queue-press*-to-request-callback.wav', 'Added via CLI');"
fwconsole reload
Yes, that is a start, The script will have to do all at as user asterisk.
@KNERD: I ran into a few problems. First, many Incredible PBX systems have a skyetel trunk enabled by default even though it's not registered. Disabling it and choosing another default outbound trunk never gets reset for the qcallbacks. So I guess the moral of the story for now is to make sure your Outbound Routes are properly configured and working BEFORE installing qcallback.
Another gotcha was attempting to set the qcallback options. When it attempted to write the settings to /etc/asterisk/queues_post_custom.conf, I got a message that the system was read-only even though it wasn't. The only way around this was to edit /usr/lib/systemd/system/php8.2-fpm.service, change ProtectSystem=full to false, then issue systemctl daemon-reload followed by systemctl restart php8.2-fpm.service.
Finally, when I called in with the queue answering calls, all I got was music on hold. Pressing * initiated the qcallback setup but the initial prompt message never played even though it played my calling phone number and then hung up. Then the return calls failed because they were sent to the disabled skyetel trunk rather than the default outbound route.
As for the recordings, I don't see a way to programmatically add them. I think users are going to have to download them to their desktop and then add them in the GUI using the Custom Recordings option. Otherwise, they never played even after manually re-enabling them in the GUI following the setup I listed above.
Hope this helps.
Hope this helps.
The for queue answering the calls and playing any announcement entering the queue, that is that is handled by the Queues module. This one does not have an intro announcement. Only an announcement for letting the caller know there is an option to have a callback instead of waiting. That starts playing after 1 minute of waiting at default. Once you press the callback key (default '*') it will play the number you are calling from. Since there is not enough words from Asterisk/FreePBX to tell the user what to do like press 1 if the number is good, or press 2 to call back to another number. Is there something wrong with that?
For the actual call back, I guess I could put a setting for which outbound route for each callback to use. Can you provide a call log for that event so I can look it over?
Also for the read-only error, can you give me the exact message? I have never seen this before.
I Will eventually get around to adding the recordings.
Thanks.
I see the issue. I am using Debian 13 on this version which has PHP 8.4. I will see about making it compatible with Debian 12 also, but EOL is already getting close as it is two years away.
This is why we did not see a complaint from CPA Joe about this. He is also using Debian 13.
Our current iPBX 2026 installer for Debian 13 loads PHP 8.2 which is what I was using with Debian 13. I will update it and see if that fixes things.
UPDATE: Nope. PHP 8.4 actually breaks the FreePBX 17 install.
PHP Warning:  Undefined array key "ASTLOGDIR" in /var/www/html/admin/libraries/utility.functions.php on line 584
PHP Fatal error:  Uncaught Error: Class "FreePBX" not found in /var/www/html/admin/libraries/utility.functions.php:587
I made a new installation of Incredible PBX 2026 using these instructions then tested the module with different settings.
I am unable to recreate the error.
The latest and greatest from @KNERD added a "Scheduled Queue Callbacks" reports page and a new "security" tab with all of the pricey Caribbean area codes blocked by default...
mkdir qcallback
chown asterisk:asterisk qcallback
chmod 775 qcallback
cd qcallback
wget https://filedn.com/lBgbGypMOdDm8PWOoOiBR7j/IncrediblePBX2026/CONTRIBUTORS/qcallback-17.0.4.3_Beta_4.tgz
tar zxvf qcallback-17.0.4.3_Beta_4.tgz
cd agi-bin
cp -p * /var/lib/asterisk/agi-bin/.
fwconsole ma install qcallback
/root/sig-fix
/root/sig-fix
fwconsole reload
hi ward, happy saturday, can i ask another favor please..........................can you send me instructions how to install open vpn on IPBX 2026, I was successful in installing it on vital pbx3 and 4.5, and i have wireguard running on IPBX
Welcome to Incredible PBX
Incredible PBX 15.0.38 'Incredible PBX PUBLIC'
but i cannot remember how i got wireguard running on that version and just figured it might be better ti run open vpn on IPBX 2026, thank you as always, joe
OpenVPN tutorial is here. But I would encourage you to switch to Tailscale which is much more flexible.
curl -fsSL https://tailscale.com/install.sh | sh
tailscale up
# then connect to your account with the provided browser link
# and don't forget to whitelist tailscale in the firewall below
/root/add-ip tailscale 100.64.0.0/10
tailscale up
got it, will do.....................do i need to download any apps so i can reach the IPBX 2026 via android groundwire app? i needed the wireguard app running on my android
You can install Tailscale there, too. Then use the Tailscale IP address of the platform in your Groundwire app.
Once you get Tailscale set up, in the portal for each server you can disable key expiry in the 3 dots and never have to worry about expiration dates going forward.
Latest Posts
clifford06
