I don't think you install t*f*t*p by running "install-polycom". What are you trying to say?
I don't believe the instruction say anything about that script - can you tell me why you did that?
Did you set the dhcp option 66 as outlined inthe instructions?
i followed the directions to the letter. however from what i see if you copy the code, which is somewhat hidden. and paste it into putty or whatever SSH program. it finishes running everything for you.
so this is what sets the options 66?
Running the install-polycom script is not a part of the process for example. I may be way off here but it seems like the firmware that is loaded with setup-polycom is not supported on the ip500, I think you have to use older firmware for that phone.
Live Chat
Video Conferencing
Check your inbox!
