Installing apt-swift
wvroger
i have followed the directions on the nerdvittles website without success. the app_swift.so is not loading.
I am running asterisk 1.4.13 do I need to upgrade?
Roger
I'm running into a similar problem.
root@pbx:/usr/src/app_swift-0.9.1 $ asterisk -rx "core show application swift"
Your application(s) is (are) not registered
same problem....
Your application(s) is (are) not registered.
order i did it in.
update-scripts
update-fixes
update-source
then did nerdvittle install as instructed.
I could hear the message "hello world" across usb headset but same error message came up about not being being registered when i continued down instructions.
Do we need to be actually registed to not get this message?
To test the install process i reverted to a old snapshot (in vmware ) and redid the entire process. During this snapshot reversion i appeared to have hosed my host OS windows vista 64 ultimate as i cannot use the keyboard or mouse now at all. will work on my probably unrelated host os problem and see if i can get pbxinaflash up and working again. I believe my usb has caused some random error and i will take me a bit to sort it out.
unplugging and replugging in ps2 and usb devices as we speak ...
merlyn
ok host computer is up and working again.
pbxinaflash is up and working again. Appears plugging in a usb headset that was working in pbxinaflash before caused all kinds of errors.
to fix it i had to shut down the host machine unplug all ps2 and usb devices. boot KVM (as in kick it across room). didnt help had to continue ...
shutdown 2nd computer on kvm and reboot KVM (as in pick up the kvm and kicked it again across room) and voila everything is happy again.
Now where was I ... oh yeah ..... swift install .... i was just installing a few applications in 1.4 before i tried doing a 1.6 asterisk install .... hummm i think i will just wait a bit on the 1.6 trial ... :wink5:
DISCLAIMER !!!... this was a dramitization ... no KVM switch was actually harmed during the making of this forum post!!!
merlyn
Same here...
Well, there were a couple of problems. Thanks for the feedback. Log into your server as root and issue the command: ldconfig
Next, that damn WordPress treatment of quotes bit us in the butt again. Fancy quotes are not the same as regular quotes, nor is the fancy apostrophe the same. So issue these commands:
sed -i 's|David-8kHz|Allison-8kHz|' /etc/asterisk/swift.conf
amportal restart
If you still have problems, post another message. Thanks again for feedback.
SUCCESS!!
Thanks Uncle Ward.
Instead of doing the whole thing over again I did the 'ldconfig' then I did this:
cp /usr/src/app_swift-0.9.1/swift.conf.sample /etc/asterisk/swift.conf
Just to reset the config file before re-running the 'sed' command.
That worked just fine for me.
You know your the greatest, right Ward?
Allison just keeps telling me that over and over. What a great girl. :yesnod:
Anyone know how I could make swift read a file on disk from the dialplan? I'd like to be able to edit the spoken text from a webpage.
(without the danger of breaking the dialplan... )
It's not supported real-time in the Asterisk implementation. Because of the licensing scheme, you will be better served by generating the .wav file on the fly from the web site and then letting Asterisk play back the file. You can write out a .wav file in under one second. Playing a text file with Cepstral over the telephone ties up your license for the entire time its playing. :idea:
Do I need to use the 8k voices?
This is a great addition, but I was wondering if I really need to use the 8k voices, or can I use the normal voice so I can use the voice in other situations like home automation? I'd rather not buy a license just for Asterisk.
I know the regular voice works with Asterisk...I've already tried that. But does using the 8k voice as opposed to the normal voice buy me anything?
<slaps forehead>
Thanks, Ward. I should have though of that. I'll just generate the .wav with the command line swift and link to that.
What it buys you is .wav files that work with Asterisk without conversion. I don't think you're going to notice a difference for home automation projects.
How do I generate the .wav file on the fly from the website?
Thanks,
Jeff
PHP has a system() function to execute Linux commands, e.g.
swift -f inputfile -o outputfile
Ok, I've looked in the source code for app-swift, and it sets the swift voice engine to output at 8kHz. In fact, it is setting the swift engine to output 8kHz ulaw raw output. So I would think that the 16kHz desktop voices would also work fine and generate the same output that the 8kHz voice does.
I did the following:
#swift -n Allison -o test.wav "hello world"
#aplay test.wav
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 16000 Hz, Mono
Then I did this one:
#swift -n Allison -o test.wav -p audio/sampling-rate=8000 "hello world"
#aplay test.wav
Playing WAVE 'test.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
So the standard 16kHz desktop voice generated a 8kHz sample.
Finally, with the Allison 8k voice:
#swift -n Allison-8kHz -o test2.wav "hello world"
#aplay test2.wav
Playing WAVE 'test2.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Mono
The WAV file generated by the 8K voice is exactly 200 bytes larger than the other one.
According to voip-info.org, 16bit 8kHz mono is optimal for Asterisk.
:( "Your application(s) is (are) not registered"
Can anyone else see where I am going wrong, If I only installed Allison do I need to type David-8kHz as well?
history..
First I Installed Cepstral
Tested it >> "the computer speaks"
Intstalled app_swift-0.9.1 make..and make install.
Very Carefully Typed the following from a root prompt first using ldconfig here is a copy/paste of the routine:
root@pbx:~ $ ldconfig
root@pbx:~ $ sed -i 's|David-8kHz|Allison-8kHz|' /etc/asterisk/swift.conf
root@pbx:~ $ amportal restart
STOPPING ASTERISK
<snip> asterisk reload routine. <snip>
FOP Server Started
root@pbx:~ $ asterisk -rx "core show application swift"
what am i missing?
