I have been using a Shuttle Box as my PBXinaflash server for a while
This little Shuttle Box has been around since 2003! Well it happened. The power went off because of rain and it died. It didn't help that the box had been shut off for about 15 minutes total in the last 3 years.
So I decided it is time to upgrade from that P4 with 512 megs of ram to something new and exciting! AKA, something cheap at Frys
I got a Asus M4A78L-M motherboard, with 2 gigs of ram and an AMD 1640 Processor.
Well I get a kernel panic during the install. I get the menu to where you can hit enter, type auto, etc. If I hit enter or type auto, the panic occurs. This is the PBX in a flash 1.4 32 bit. For my own sanity, I downloaded a CentOS 5.4 live cd. It boots fine and pops up a nice gui.
So my question is . . .
How do I handle this now? Do I do a 5.4 install and then . . . how do I do a PBiAF install? Do I keep my tears going and worry about having to install some lesser product?
Thanks.
dave
Thanks.
dave
