Experimental PIAF/CentOS 5.5
wardmundy
Nerd Uno
While we eagerly await Tom's new build of PBX in a Flash for CentOS 5.5, we've uploaded an experimental version to SourceForge just to let a few of the true pioneers shake out the kinks.
Experimental PIAF version with CentOS 5.5 http://nerd.bz/cdtp78
Then try loading The Incredible PBX for the ultimate turnkey system. http://nerd.bz/cVxqYF
Ward -
I'll try this on my new Acer Revo unless you know of any immediate limitations. Will it allow me to load Asterisk 1.6.2.7?
It's running on one of mine. Don't know why any version of Asterisk would be a problem. Let me know if it smokes. :sifone:
Got it working on my Revo. Going to move some of the production configurations over to it and see if I can use it for production today.
Are there any known issues with this release yet?
No Problems So Far
I've loaded this on my Dell SC420 Celeron test system and it works fine. I also loaded it on an Acer Revo and got it going as well. Preliminary tests show there to be no issues on either system.
It's been working wonderfully for the past two days day (even when Vitelity went down - it's an XO issue, not Vitelity). Just another reason for multiple providers ;)
Downloaded a 5.5 here as well, Hardware is a Dell Poweredge 840 that had a bad drive, so as long as I am rebuilding it I wanted to go current.
Did see a few messages fly by that I need to look at latter but 1.6 Sataraid seems to be a solid install.
PS: Thanks for staying with the older FreePBX release. 2.5.2.3 Makes migrating older boxes much easier.
FreePBX 2.5 will be replaced by 2.6 in the "official" PIAF builds. But this experimental one will still be around.
Has Anyone Got Sendmail Working with Centos 5.5?
Ward -
I loaded a new Revo with this load and everything is pretty good except I can't get it to send me an email anymore. I went through the whole modification for Comcast port 587 as previously discussed but something seems to be different with this version?
Any pointers? I have tried the gmail route as well but it also will not work.:banghead:
Nothing has changed. Usual setup with Gmail should work fine. Don't forget the quotes. :wink5:
I'm wondering if Sendmail is changed in Centos 5.5. I simply cannot get email notifications to work with Gmail or Comcast. I've started with a fresh install. Even removed sendmail and sendmail-cf and reinstalled but I keep getting a reject. Its been so long since I had to deal with this that I'm racking my brain trying to figure out what's wrong. ....And YES I have the quotes.
64Bit version ???
is there a 64 bit version available ???
also, in file ksnet32.cfg, the following is found:
install
url --url ftp://mirrors.kernel.org/centos/5.1/os/i386/
Shouldn't this be 5.5 ??? or is there a reason to stick with 5.1 repositories ???
awesome :)
waiting patiently ...
have made a new centos 5.5, will do a post install of piaf once you have it ready :)
anyone been able to get RxFax to compile under 5.5?
root@pbxtcs:~/fax/agx-ast-addons $ ./build.sh
CMake Warning (dev) in CMakeLists.txt:
  No cmake_minimum_required command is present.  A line of code such as
    cmake_minimum_required(VERSION 2.6)
  should be added at the top of the file.  The version specified may be lower
  if you wish to support older CMake versions for this project.  For more
  information run "cmake --help-policy CMP0000".
This warning is for project developers.  Use -Wno-dev to suppress it.
-- Configuring done
-- Generating done
-- Build files have been written to: /root/fax/agx-ast-addons
[ 12%] Building C object CMakeFiles/app_devstate.dir/app_devstate.o
cc1: warnings being treated as errors
/root/fax/agx-ast-addons/app_devstate.c:45: warning: initialization from incompatible pointer type
/root/fax/agx-ast-addons/app_devstate.c:45: warning: initialization makes integer from pointer without a cast
/root/fax/agx-ast-addons/app_devstate.c: In function ‘devstate_cli’:
/root/fax/agx-ast-addons/app_devstate.c:61: warning: ‘ast_device_state_changed_literal’ is deprecated (declared at /usr/include/asterisk/devicestate.h:192)
/root/fax/agx-ast-addons/app_devstate.c:63: warning: ‘ast_device_state_changed_literal’ is deprecated (declared at /usr/include/asterisk/devicestate.h:192)
/root/fax/agx-ast-addons/app_devstate.c: In function ‘devstate_exec’:
/root/fax/agx-ast-addons/app_devstate.c:96: warning: ‘ast_device_state_changed_literal’ is deprecated (declared at /usr/include/asterisk/devicestate.h:192)
/root/fax/agx-ast-addons/app_devstate.c: At top level:
/root/fax/agx-ast-addons/app_devstate.c:122: error: ‘AST_FORMAT_MAX_AUDIO’ undeclared here (not in a function)
/root/fax/agx-ast-addons/app_devstate.c: In function ‘action_devstate’:
/root/fax/agx-ast-addons/app_devstate.c:164: warning: ‘ast_device_state_changed’ is deprecated (declared at /usr/include/asterisk/devicestate.h:175)
make[2]: *** [CMakeFiles/app_devstate.dir/app_devstate.o] Error 1
make[1]: *** [CMakeFiles/app_devstate.dir/all] Error 2
make: *** [all] Error 2
