Sorry, it was too long. Changed it to begin when it starts recording the message.
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:57] VERBOSE[10898] app_voicemail.c: -- Recording the message[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:57] VERBOSE[10898] app.c: -- x=0, open writing: /var/spool/asterisk/voicemail/default/102/tmp/crZEDc format: wav49, 0xb6b0c788[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:57] VERBOSE[10898] app.c: -- x=1, open writing: /var/spool/asterisk/voicemail/default/102/tmp/crZEDc format: gsm, 0xb6b0bec0[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:57] VERBOSE[10898] app.c: -- x=2, open writing: /var/spool/asterisk/voicemail/default/102/tmp/crZEDc format: wav, 0xb7678628[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:59] VERBOSE[10898] app.c: -- User ended message by pressing #[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:00:59] VERBOSE[10898] file.c: -- <SIP/(XXXX) XXX-XXXX -00000016> Playing 'auth-thankyou.gsm' (language 'en')[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:00] VERBOSE[10898] pbx.c: -- Executing [dovm@macro-vm:3] Goto("SIP/(XXXX) XXX-XXXX -00000016", "exit-SUCCESS,1") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:00] VERBOSE[10898] pbx.c: -- Goto (macro-vm,exit-SUCCESS,1)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:00] VERBOSE[10898] pbx.c: -- Executing [exit-SUCCESS@macro-vm:1] GotoIf("SIP/(XXXX) XXX-XXXX -00000016", "0?exit-RETURN,1") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:00] VERBOSE[10898] pbx.c: -- Executing [exit-SUCCESS@macro-vm:2] Playback("SIP/(XXXX) XXX-XXXX -00000016", "goodbye") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:00] VERBOSE[10898] file.c: -- <SIP/(XXXX) XXX-XXXX -00000016> Playing 'goodbye.gsm' (language 'en')[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [exit-SUCCESS@macro-vm:3] Hangup("SIP/(XXXX) XXX-XXXX -00000016", "") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] app_macro.c: == Spawn extension (macro-vm, exit-SUCCESS, 3) exited non-zero on 'SIP/(XXXX) XXX-XXXX -00000016' in macro 'vm'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] app_macro.c: == Spawn extension (macro-exten-vm, s, 18) exited non-zero on 'SIP/(XXXX) XXX-XXXX -00000016' in macro 'exten-vm'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: == Spawn extension (ext-local, 102, 2) exited non-zero on 'SIP/(XXXX) XXX-XXXX -00000016'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [h@ext-local:1] Macro("SIP/(XXXX) XXX-XXXX -00000016", "hangupcall,") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/(XXXX) XXX-XXXX -00000016", "1?skiprg") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Goto (macro-hangupcall,s,4)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [s@macro-hangupcall:4] GotoIf("SIP/(XXXX) XXX-XXXX -00000016", "1?skipblkvm") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Goto (macro-hangupcall,s,7)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [s@macro-hangupcall:7] GotoIf("SIP/(XXXX) XXX-XXXX -00000016", "1?theend") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Goto (macro-hangupcall,s,9)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: -- Executing [s@macro-hangupcall:9] Hangup("SIP/(XXXX) XXX-XXXX -00000016", "") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] app_macro.c: == Spawn extension (macro-hangupcall, s, 9) exited non-zero on 'SIP/(XXXX) XXX-XXXX -00000016' in macro 'hangupcall'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10898] pbx.c: == Spawn extension (ext-local, h, 1) exited non-zero on 'SIP/(XXXX) XXX-XXXX -00000016'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10899] app_mixmonitor.c: == MixMonitor close filestream[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10899] app_mixmonitor.c: == End MixMonitor Recording SIP/(XXXX) XXX-XXXX -00000016[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Executing [h@macro-dialout-trunk:1] Macro("SIP/101-00000014", "hangupcall,") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Executing [s@macro-hangupcall:1] GotoIf("SIP/101-00000014", "1?skiprg") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Goto (macro-hangupcall,s,4)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Executing [s@macro-hangupcall:4] GotoIf("SIP/101-00000014", "1?skipblkvm") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Goto (macro-hangupcall,s,7)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Executing [s@macro-hangupcall:7] GotoIf("SIP/101-00000014", "1?theend") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Goto (macro-hangupcall,s,9)[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: -- Executing [s@macro-hangupcall:9] Hangup("SIP/101-00000014", "") in new stack[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] app_macro.c: == Spawn extension (macro-hangupcall, s, 9) exited non-zero on 'SIP/101-00000014' in macro 'hangupcall'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] app_macro.c: == Spawn extension (macro-dialout-trunk, s, 19) exited non-zero on 'SIP/101-00000014' in macro 'dialout-trunk'[/font]
[FONT='Helvetica','sans-serif'][2010-11-08 07:01:01] VERBOSE[10897] pbx.c: == Spawn extension (from-internal, 1XXXXXXXXXX, 7) exited non-zero on 'SIP/101-00000014'[/font]
