Conference Rooms / Group Paging Not Working
I am having similar issues now after an update-scripts/source/fixes. I get an error of Module zaptel not found.
I tried...
cd /usr/src/zaptel
make install-udev
That didn't help.
Thank you guys. That worked for me too. Granted I still don't have a zap show channels command in asterisk. I can live without that.
Got this error
root@pbx:~ $ genzaptelconf -sdv
unknown parameter -s, Aborting
genzaptelconf: generate zaptel.conf
genzaptelconf -dv
unknown parameter -d, Aborting
After this:
genzaptelconf -v
STOPPING ASTERISK
Asterisk Stopped
STOPPING FOP SERVER
FOP Server Stopped
Generating '/etc/zaptel.conf'
DEBUG: resetting channels lists
Generating '/etc/asterisk/zapata-auto.conf'
Reconfiguring identified channels
Zaptel Version: 1.4.11
Echo Canceller: MG2
Configuration
Channel map:
0 channels to configure.
Unloading zaptel hardware drivers:.
Loading zaptel framework: [ OK ]
Waiting for zap to come online...OK
Loading zaptel hardware modules: tor2.
wct4xxp.
wcte12xp.
wct1xxp.
wcte11xp.
wctdm24xxp.
wcfxo.
wctdm.
wcusb.
xpp_usb.
No hardware timing source found in /proc/zaptel, loading ztdummy
Running ztcfg: [ OK ]
SETTING FILE PERMISSIONS
Permissions OK
STARTING ASTERISK
Asterisk Started
STARTING FOP SERVER
FOP Server Started
Checking channels configured in Asterisk:
Chan Extension Context Language MOH Interpret
pseudo from-zaptel en default
You have new mail in /var/spool/mail/root
root@pbx:~ $ reboot
Conference start working like charm
Thank you ALL for your help!
I got it to work, but now after every reboot I have the same issue and the way to solve it is to run each time after the reboot:
service zaptel restart
which brings ONLINE the ZAPTEL.
Is there a way to avoid having to do this after each reboot?
I have no zap hardware.
Attached the output
genzaptelconf -sdv
Notice: Configuration file is /etc/zaptel.conf
line 0: Unable to open master device '/dev/zap/ctl'
1 error(s) detected
/usr/local/sbin/genzaptelconf: line 1124: /etc/init.d/asterisk: No such file or directory
Unloading zaptel modules:
Temporarily moving zaptel.conf aside to work around broken modprobe.conf
Test Loading modules:
- wct4xxp
- wcte12xp
- wcte11xp
- wct1xxp
- wanpipe
- tor2
- torisa
- qozap
- vzaphfc
- zaphfc
- ztgsm
- wctdm24xxp
- wctdm
- opvxa1200
- wcfxo
- pciradio
- wcusb
- xpp_usb
Generating '/etc/zaptel.conf and /etc/asterisk/zapata-channels.conf'
Zaptel Version: 1.4.12.1
Echo Canceller: MG2
Configuration
Channel map:
root@pbx:~ $
UPGRADING MODULES
Downloading ivr
Untarring..Done.
Checking if announcements need migration..already migrated
Checking for timeout_id..not needed
Checking for invalid_id..not needed
Checking for retvm..not needed
ivr installed successfully
Downloading music
Untarring..Done.
music installed successfully
Downloading paging
Untarring..Done.
paging installed successfully
Return
DONE MULTIPLE TIMES genzaptelconf -sdv with reboot
root@pbx:~ $ service zaptel restart
Loading zaptel hardware modules:No hardware timing source found in /proc/zaptel, loading ztdummy
root@pbx:~ $ zap show channels
-bash: zap: command not found
root@pbx:~ $ zttest
Opened pseudo zap interface, measuring accuracy...
99.943459% 99.967873% 99.963669% 99.941025% 99.963776% 99.941307%
--- Results after 6 passes ---
Best: 99.968 -- Worst: 99.941 -- Average: 99.953518, Difference: 99.988413
root@pbx:~ $
