on a vpslink server. It worked just fine. I ran update-scripts and then update-source and now it is running at 1.4.19.1.
The only hiccup was that I had to update the passwords individually as passwd-master didn't seem to do the trick. That and I had to run update-fixes, reboot and run fixes again to gain access to FreePBX...
It all appears to be fine. I do some actual testing in the morning.
Incidentally, since I attended Linuxfest NW, I got a coupon for trial service "LFEST08" and I used it at http://vpslink.com/linuxfest
90 Days for $3.00. Not bad to test a remote install procedure.
As convenient as PiAF is, I think your better off installing from scratch if your doing it remotely.
http://www.powerpbx.org/content/fre...l-guide-centos-v5x-asterisk-v14x-freepbx-v24x
Hi All:
I have a solution here for installing PBX in a Flash on an OpenVZ VPS which may help you -- I was looking for a similar concept. Joe is 100% right the tricky part is the dependencies... I am confident I have too many packages in my installer but have not had time to cut them back yet. Here are my notes: http://chrisschuld.com/2008/11/installing-pbx-in-a-flash-piaf-on-an-openvz-vps/
This is the first writeup that I have found that actually works in an Open VZ VPS, even a 64-bit one with a few alterations. For some reason the 32-bit and 64-bit PBIAF ISO's do not have all of the same packages on them which you run into when copying over the 13 RPMs listed in the writeup. They are all present on the 32-bit, but several are missing from the 64-bit and can be found on the net except for one (ez-ipupdate, which a hosted VPS really shouldn't need anyway).
Decided to play around wit a Proxmox (http://pve.proxmox.com)... following the instructions (and the comments on removing the tty9 that I couldn't make work) and been happy since... my atom box is now running my PBX and two small virtual machine, no stutter!
And while you could still use that piaf server for other purposes, i feel its better to keep the applications separate when possible for security and maintenance reasons.
Live Chat
Video Conferencing
Check your inbox!
