ostridge
- Jan 22, 2015
- 1,813
- 625
copy .ovpn into /etc/
??not found or is it in the install script still todo ? Edit looking in the iPBX install script there is lots of ovpn stuff so therefore script should fix.
FWIW without the above the reload restart fails:-
systemctl status openvpn2021.service
● openvpn2021.service - openvpn2021
Loaded: loaded (/etc/systemd/system/openvpn2021.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Condition: start condition failed at Sun 2021-10-10 22:15:44 UTC; 52s ago
└─ ConditionPathExists=/etc/openvpn-start was not met
Oct 10 22:13:13 instance-20211010-2136 systemd[1]: /etc/systemd/system/openvpn2021.service:12: Support for option SysVStartPriority= has been removed >
Oct 10 22:15:44 instance-20211010-2136 systemd[1]: Condition check resulted in openvpn2021 being skipped.
