TIPS Cellular.everything
There is no international roaming. Visible only works in the US, Canada, Mexico and Puerto Rico. Hold on to your T-Mobile until your vacation is over.
Yep - exactly what I thought. T-Mobile pretty decent for international. I get free 2G (woo woo - 128kb) ... but can buy a 15GB LTE with unlimited calling for 30 days for $50.
Or just get a temporary sim card in Europe and save a bundle.
@krzykat Very much this. Sim cards and calling rates almost anywhere there will be pennies on the dollar vs even great roaming rates.
And if you wanna get creative and make calls home to the US just get a local (to where you'll be) DID and use call-in through your pbx.
Just Smart shop. I have a Google Pixel phone and it supports eSim. Easy breezy SIM purchase and activation. For recent travel, I bought a data only eSIM and used my PBX. I would never buy a plan based on it's international roaming, unless it is a total bargain. I shop eSim providers every time I travel as prices vary a lot.
I think you mean calls are to US, Canada, Mexico, Puerto Rico. Once in far enough into Mexico, you lose the signal from the US towers, and there is no more signal for the phone to connect to using CDMA
VISIBLE NOW SUPPORTS ESIM DOWNLOAD!
I was checking my Visible app today and it offered to move my SIM to the phones ESIM. It worked after I figured out what it wanted. If it asks for your IMEI, you need to give it the IMEI from the slot for you ESIM. On my Pixel phone, I have one physical only slot and one ESIM only slot. Initially, I thought they wanted the current IMEI from my physical slot but the program barfed trying to download the new ESIM to the physical slot. After a chat with Visible on the app, they told me to remove the old SIM card, remove the Visible app, reboot the phone and reinstall the Visible app. When I did all that and accessed the Visible app again, it downloaded the ESIM correctly.
This way, if I want to check out other carriers, I can use the SIM card they send and not worry about not having Visible working at the same time.
That's awesome, and great timing. Still only have one account on Visible, my daughters, and we're going overseas in a couple weeks. So if we did this, we should be able to grab a pay as you go SIM where we are and she could use that while there, but still have access to her Visible account (if we were where it is usable) at the same time, correct?
Depending on the phone, that is correct. On my Pixel, when you have both SIM and ESIM, you have to select which you want to be active for data. On some phones, you have to select one as default and the other as failover. Most phones let you toggle from the Settings > Networks screen. At one point, I had T-Mobile on my ESIM and Visible on the physical SIM. I could get a call on either SIM but had to set a primary for outbound calls.
I'd be curious how Visible would handle wifi calling in a foreign country. Will it just not work or will it behave normally? You can find out.
The simplest explanation was given to me by an ATT employee referring to MVNO's. She simply said "They get what we don't need". Simply put, they are selling otherwise-unused data at any given moment for a low price, when otherwise it would go unused altogether. The full -rate customers get the full capability of the network, and the discounters get what is left over...
Visible WiFi calling works in Canada, as we were there last October and had service over WiFi calling..
Worked for me with Galaxy Note20 5G. Didn't seem to mind the SIM card still being place. In fact, it said it had to be even though I had removed it. The trick as you noted was to enter the IMEI of the eSIM even though it prompts for the "phone's IMEI." Also need to be sure you have the latest Visible app on the phone but no need to remove it and reinstall it. Simply updated it in place.
Yep. That is what messed mine up. They were able to change the request to the correct IMEI. Had I entered the eSIM IMEI, I would have not had an issue. They really need to update the app to ask for the eSIM IMEI in order to prevent confusion.
Think I'll be able to tell you in a few weeks.
As long as it has internet and Wi-Fi connection, it functions just as a normal cell phone.
Please report back.
I've used it in Mexico, and long as I had Wi-Fi/internet access. it functions just like normal. I don't think it works in emergencies and the signal indicator it could not connect to anything.
Well I believe Mexico and Canada are part of he Visible plan. I'm more curious if you were in Europe, would your wifi access to the service be blocked because of IP address or geolocation information? Obviously, you could not call local numbers in the foreign country because of the calling plan but I would hope you could still call back to US/Canada/Mexico numbers regardless.
