@w1ve: I smell a rat...
Q: What's Changing:
A: Since we're making it easier to save with our new plans this means we're also making some changes to Party Pay. We will be closing Party Pay and locking all Party Pay discounts based on a Members Party status on October 18th, 2022.
Yes, Party Pay is changing, BUT in the meantime, your savings aren’t. Members who remain on the Visible Unlimited plan will be able to keep their current plan and Party Pay discounts (locked in at their Party size level as of 10/18) for as long as we support the plan
Q: I’m a new member on the Visible or Visible+ Plan, why don’t I see Party Pay?
A: Our members loved the discounts, but not the hoops they had to jump through to get it. So, we made our new plans simpler and unlocked a flat-rate monthly cost for all plans from day one, with no additional action needed by members.
Q: When is it changing?
A: Starting August 17, 2022 Party Pay will only be available to Visible Unlimited Plan members - these members can still join/switch existing Parties until October 18th, 2022 when all Party Pay discounts will be locked and the Party Pay tab in your account will be removed.
(But don’t worry, as long as you're in a Party before we lock in your discount on October 18th, 2022, you will continue to get your Party Pay discount as long as you remain on our Visible Unlimited plan.)
Q: What happens when I change to a Visible or Visible+ plan?
A: At the time your plan changes, your Party will be removed from your account. This will remove the discounts from your Party applied to your prior plan and will decrease your previous Party’s size by one. Don't forget to update your device software to the latest version before you activate your Visible or Visible+ plan.
Q: When should I leave my Party?
A: You don’t have to leave your Party, you can stay while you learn about the new plan offerings. Once you know what plan you want, you’re welcome to move over and your Party will be automatically removed from your account when you do.
Q: When is the last day I can join/switch my Party?
A: Existing Parties will be available to join/switch until October 18th, 2022. Your discounts will be locked into place as long as you remain on our Visible Unlimited Plan.
Q: What happens if someone leaves my Party before Party Pay is removed?
A: Your monthly price will still fluctuate depending on the # of people in your Party before it is locked on October 18th, 2022. If someone leaves your Party after August 17th, another member on the Visible Unlimited Plan can join by searching for it on the Party Pay tab. Or you and your Party can join a bigger Party and not have to worry about your discount going up and down.
We heard the VISIBLEROCKS party is awesome! Search them any time in the Party Pay tab.
Q: How do I join a Party?
A: Go to your “Party Pay” tab in your account and either join a top 5 Party or search for a friend’s Party in the search bar
Q: My party is shrinking, how do I join a larger Party?
A: It’s easy as 1, 2, 3. First, go to your “Party Pay” tab in your account, scroll down and click “Leave Party”. Second, once you’ve left, you will click “get started” and you will be given the option to join/search for other Parties. And finally, join one of the top 5 Parties on that page.
Q: When will Party Pay be removed?
A: On October 19th, 2022 you will no longer see Party Pay in your account and not be able to join/switch Parties. But don’t worry, your savings are safe! As long as you're in a Party before we lock in your discount on October 18th, 2022, you will continue to get your Party Pay discount while on our Visible Unlimited plan.
Q: What happens when Party Pay is locked on my account and my Party members’ accounts?
A: Your Visible Unlimited Plan price will be locked and you’ll be able to join one of Visible’s new plans. After October 18th, 2022 you will not be able to make any changes to your Party.
Q: Should I leave the Party prior to the end date?
A: That’s up to you and your Party. When you’re ready, check out our
new plans and choose the right option for you.
